OSPF has failed to activate. OSPF needs to be restarted.
Check diagnostics to try to determine the cause of the failure. In particular, check if there is sufficient memory available. If this does not resolve the problem, contact support with details of the problem.
Error
%p1% Failed to activate. Router ID = %p2%
| Name | Type |
| p1 | String |
| p2 | DecByteArray |
